SOURCE: I HAVE A MGX MOUNTAIN BIKE. WERE THE PEDAL ARE
im certain that model has a 3 piece crank set up. the inner crank bearing jam nut has loosened up or the bearings themselves have gone bad.first check to see if its tight, if it is then it will require a replacement set of bearing that are a pretty standard size to all bikes and can be purchased at nearly every bike shop.
SOURCE: can i stiffen up the tension in my front forks on
Sorry to inform you, but there is no adjustments available for the forks that come with your bike. Adjustable forks (just the fork) start in around $250-.
On the positive side since there is not adjustment capability the fork does not need regular servicing like the adjustable forks.
SOURCE: I have a Mongoose Dual
It's prabably easier to buy a whole new hub. And for ablout another $20 you get a whole new tire. You should do that. Have a bike shop do it because it can be tricky.
SOURCE: what are the caponents to
The number of speeds is irrelevant and tells us nothing about the hub but the actual manufacturer and design of the hub are the determinants as there are variations. You could do some web searching for an answer. Shimano documents their components very well, for example.
Some good general resources...
http://sheldonbrown.com/k7.html
http://www.parktool.com/blog/repair-help/categories/hub-service
im looking to buy the front brake aassembly for this bike (omitted from previous post) or the mgx website do i might order direct from the manufacturer
