Pump was just replaced by a technician and first time I tried to use it I got the F dL error
SOURCE: Control Panel
I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
SOURCE: Kenmore Elite HE4t Washer door won't lock
If your washing machine is still under the manufacturers warranty I don't believe Sears should be charging you anything for the call. But, if you wish to steer clear of that mess and repair the washer yourself, I can give you some advice. The problem is your door latch assembly. The "Fdl" displayed is a failed door latch error code. If it is occurring intermittently right now, you are simply going to buy some time before it eventually goes bad. When it does, the washer will not run. The part number is 1094190 and costs about $50. Just to be sure, post back with comments as to your model number (located along the door frame opening) and I will research to ensure the part number is correct. The latch assemblies have not changed over recent years and are interchangeable between model numbers. If you still wish to repair yourself, I can also give you step-by-step instructions. It is not a difficult repair, but it is a little tedious. Let me know. I hope this helps you.
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws
under the bottom edge on the front of the washer. HINT: If you prop up
the front feet of the washer with some small blocks of wood, this will
make access to the screws much easier.
2. With the screws removed,
the lower panel should drop down then come off. If the panel sticks, a
light tap on either side will knock it loose.
3. Reach your hand up
inside the washer behind the front casing on the right-hand side. This
is where the door latch assembly is located.
4. At the bottom of the
door latch assembly is a small pull tab. This is the manual release for
the door. Pull the tab straight down and the door will come open.
Sometimes
these doors will not unlock for whatever reason. If there are no error
codes being generated, this could have just been a momentary glitch. If
you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
SOURCE: kenmore elite he3 - door lock
fdl error code on kenmore elite he4 washer. wont start after selecting wash cycle
SOURCE: kenmore elite he3t door locked wont open
Hi
Thanks for using FixYa. Error “dlf” means a door
latch failure. This means that you’ll need to replace the door latch assembly
however before doing that you can leave the washer unplugged for 30minutes so
that it resets itself. In the meantime when it’s unplugged just inspect the
door latch wiring to ensure all the connector plugs are intact and not loose or
broken. You can access the door latch wiring harness by removing the top panel
of the washer. To remove the top panel just remove the three screws that hold
the panel in place in the rear of the washer. With the screws removed, the
panel will slide back, and then lift off. Locate the door latch assembly behind
the front panel on the right hand side. Trace all the connectors from the door
latch to the Central Control Unit (CCU) and make sure they are properly seated
at both ends. If after doing this still the issue is not resolved then
unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
