Turn the Hannspree-brand monitor on using its remote, then press "Menu." Press and scroll the down arrow button to highlight "Setting." Press the right arrow button to enter the "Setting" menu.
Press and scroll the down arrow button to highlight "Aspect."
Press and scroll the right arrow button to change the aspect ratio from "Auto" to "Full," "Normal," Panorama" or "Zoom," depending on the type of image that you want to see on the screen.
Press "OK" on the remote control. Press "Menu" twice to exit the menu settings.
hope it helps
Hello Imc420, there are (4) four different ways to connect to the Internet. 1) To start, click on the "Start" button, in the (right "start menu" pane), select the Control Panel 'shortcut'once the nextwindow open; scroll to find, Network and Internet, click on it to open.Next, select to open the "Internet Options."To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button, and follow all the instruction carefully. 2)From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open;"this will start the setup and connection process." 3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present" Option is available?" select to open, and click on the Connectivity Doctor,follow all instructions thereafter. (4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories, select to open: if you have the [Windows Mobility Center], open the program; there will be a Wireless Network 'Turn-on and Off Switch" Important"Always! Click Apply, Ok, and Restart the computer after making changes to the computer." "Did this solution help?" If so, "helpful Rating Feedback appreciated, thanks paul7of9."
Hello sanieevclair, there are (4) four different ways to connect to the Internet. 1) To start, click on the "Start" button, in the (right "start menu" pane), select the Control Panel 'shortcut'once the nextwindow open; scroll to find, Network and Internet, click on it to open.Next, select to open the "Internet Options."To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button, and follow all the instruction carefully. 2)From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open;"this will start the setup and connection process." 3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present" Option is available?" select to open, and click on the Connectivity Doctor,follow all instructions thereafter. (4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories, select to open: if you have the [Windows Mobility Center], open the program; there will be a Wireless Network 'Turn-on and Off Switch" Important"Always! Click Apply, Ok, and Restart the computer after making changes to the computer." Thank you for using FixYa; I hope this information is helpful! paul7of9
Take one memory stick out and test. Then do the other. Also checking each memory slot.
If not solved. When the computer starts, continually press F8 until you get startup menu- select SAFE MODE and fix the driver or software that is in startup
or
Roll back to last known configuration that worked.
While you are there- disable Auto Reboot on Failure.
In Windows XP you can open My Computer from the Start menu. To open My Computer, click on the Start button, then click on "My Computer" link as shown in the attached image.
To save the "My Computer" icon on the Desktop, right-click on "My Computer" Link in the Start Menu, and click on "Show on the Desktop" link.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Usually the firewall settings are found in Control Panel on your computer. If you are running Windows XP, click on the Start button and select "Control Panel" from the right side of the menu. Select "Windows Firewall" (or if you are in Category view, "Security Center" then "Windows Firewall"). Under the "Exceptions" tab, if Yahoo! Messenger is not already in the list, click "Add Program", then select from the list shown. If Y! isn't shown, click "Browse", then select Y! (usually can be found under C:\Program Files\Yahoo!).
You want XP to look like when you first got it and not in classic mode, am I correct? If that is the case, do the following:
Right click on your desktop and select Properties
Go to Themes tab and select Windows XP and press Enter
That should bring you back your screen. If that did not help, then do the following:
Right click on my computer and select Properties
Click the Advanced tab
Select Visual Effects tab
Chose either Adjust for best appearance or you can let Windows decide what's best for your system.
Finally, if that does not work go into Control Panel --> select Administrative Tools --> Services. Look for Themes in Services to make sure that is is both set to Automatic and that the services is started.
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
Hello! am Fabian,
if the start button you are talking about is that of your operating system. you may need to run disk maintenance on your system. run the check disk utility (using the command c:\>chkdsk /f on the commad prompt).
note that office professional 2007 can not run on windows 2000 pro, you need an upgrade to windows XP SP2(service pack 2).
help and support will not launch
contact support
