Cameras Logo
Jose Orench-Lugo Posted on Jan 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung sl 35 digital camera shutter does not work
Hi! the camera have new batteries. It turns on and all the menu buttons are functioning but the shutter button dont.
Anonymous
Level 3:
Genius:
  • Samsung Master 1,019 Answers
  • Posted on Jan 25, 2013
Anonymous
Samsung Master
Level 3:
Genius:
Answers
1019
Questions
0
Helped
102629
Points
1576
Sounds like defective switch assembly.
5 Related Answers
Anonymous
  • 48 Answers
  • Posted on Dec 20, 2007
SOURCE: Dsc-N2 Buttons are mulfunctioning.
Its possible the button board under the rear case has been shifted or is malfunctioning. You can try to remove the back case and see if you can realign, or reset your camera's button board. If this doesn't work, there are several online companies that can help -
DarnToothySam.com has several repair estimate opportunities, and is pretty reasonable for the price.
alexander sakelliou
  • 95 Answers
  • Posted on Jul 09, 2008
SOURCE: Camera froze up w/ no button function
hello, these units have a very fine zoom switch and can get damaged by a drop or fine sand. the zoom switch sits under the actual button. if you turn the camera on in camera mode and the display is showing the zoom on screen display then you know it is the switch.
Anonymous
  • 744 Answers
  • Posted on May 24, 2009
SOURCE: button does not work
hi
Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not workin...
thank u rate me!!
Anonymous
  • Posted on Jan 17, 2010
SOURCE: samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Anonymous
  • 11896 Answers
  • Posted on Jul 23, 2010
SOURCE: Samsung S760 digital camera.Lense does not not
You may have gotten a light debris in the lens. Just the littlest amount will cause the lens to jam. Try a can of compressed air and blowing it out.
Camera shuts off when shutter button is pressed.
I'd try replacing the battery first. It is common for a low power battery to not allow the camera's computer to read what it is supposed to do correctly. If the new fully charged battery doesn't fix it, I'd then contact customer service.
INTOVA IC12 CAMERA, ON/OFF BUTTON WORKS, SHUTTER BUTTON WORKS, ALL OTHER FUNCTIONS ARE INTERMITTENT. THEY DO NOT WORK MOST OF THE TIME! BATTERY HAS FULL CHARGE REMOVED BATTERY FOR 30 MINUTES - NO...
Hi keith_carr877,
Please contact Intova directly for assistance @ (877) 837-0074 or (808) 837-0074 or e-mail [email protected]. We'll be more than happy to help you.
Thanks,
Intova
My digital camera FinePix A900, keeps turning off when I turn it on. Unable to pull any menus. Batteries are good. any suggestions, is it fixable or do I have to buy a new one?
Try pressing the playback button to turn the camera on. This should turn the camera on just so that you can view any pictures stored on the card or internal memory. You can also access the menu functions this way. Also try pressing the picture/shutter button and see if the lens extends. If the camera shuts off when you press the picture button and the lens does not move or only moves a fraction then the problem is probably to do with the lens
Lost all button functionality except power and shutter
There is a secondary battery I suppose for memory retension. It is housed where the other batteries and memory card are, the battery is a CR1220. I replaced that battery and things are working well again.
I push on the shutter button and nothing happens!
Have you tried to put new batteries in it sometimes when they start to die then not all of the functions will work and also cheap batteries can be brand new but not strong enough to run the functions
Turn off Samsung U900 Soul camera shutter sounds
press the red button on the side to open camera mode> click the little menu button (this should be the right hand button when you use your phone normaly)> scroll across to the very last option (this should be settings)> click okay> scroll down till you find an option saying shutter> click okay> chose none and click okay to exit it.
if this doesn't work put your phone in silent/ meeting mode
6helpful
3answers
Sony A100 - Buttons won't work
This sounds odd, I know, but I found a solution that worked for me. I had exactly the same problem: picture taking was wonky, menu button, playback button wouldn't work. It would do this immediately upon starting up, every time.
What worked was when I adjusted the "exposure" by holding the +/- button and turning the little dial near the shutter button. It makes absolutely no sense, but somehow it suddenly started working perfectly again. And it hasn't glitched up again yet.
Hope it works for you, too.
Shutter button +++
Hi your camera having problem inside , you may visit fixia authorized repair shop near you , just enter zip and then go , can find down right side.
1helpful
2answers
My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
2answers
Camera shuts off when you click the shutter button
The same thing happened to mine. While not a solution, my workaround has been to turn the LCD screen off when I'm shooting. It's worked so far.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
