I replaced my lamp a few months ago, and generally worked fine. It would occasionally have problems but I would reset and it would be up and running again. Now when i turn it on i hear sound but no picture and the tv turns off and I get the red light. Sometimes when I reset it would work again (usually worked all the time before but seems to not work now.) I have read many posts here and have couple of questions: 1) What is the problem? 2) I have read the problem might be the 3300uf power capicitors? Where do i locate these and how do I replace 3) How much would it cost to replace?
I am having a big Super Bowl party and need my TV to work. I have had this TV for 4 years and debating if I should buy a new TV or repair myself. Also any suggestions on new TV if I go that route or should I just repair this one?
Thanks, any insight will help
WD-73734 DLP mitsubishi. Sound but no video then turns off. Now won't turn on at all. Fault code 57( ballast problem)(hold menu and input buttons to get fault code). Still trying to trouble shoot.
SOURCE: Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
SOURCE: Red lamp light on Mitsubishi DLP 65" WD-C657
Lamp is always First to go unless power surge gets it Call Mats for Lamp 1-800-628-1118 or Find one on E-Bay got mine there for 85.00 free shipping.
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
