My Bosch dishwasher, SHU6906 is depositing grit on all the dishes on the top rack. This seems to be independent of how dirty anything was when the load started. My dishes are clean of food and food stains but covered in grit that seems to be baked on. The filter is clean and properly seated and the rinse agent is full. I've tried multiple detergents - help!
Can you remove the upper spray arm (is yours under the upper rack?)-mine unscrews and then you have to wiggle it off. Run faucet water into the arm; sometimes little bits of crud get stuck in the holes that spray the water out, and this prevents a complete rinse. I just had to clear these holes myself due to same problem (I might have a different machine, though). You can do the same for the lower arm.
