How can I delete just one picture at a time, menu only says delete all
SOURCE: Deleting all pictures from my Memory stick
go to the setup menu (I think if you press the Menu button) and select the memory stick tool then select format.
SOURCE: deleting more than one picture at a time
Turn on your camera and go to menu select set up. Then select memory stick it is under the highlighted camera, Then click on format. Go to ok then click ok. Then your camera will read all data in memory will be erased. Then click OK. Now your on your way to a clean memory stick.
SOURCE: delete & double pictures
you probably have the burst on. I have done this lots of times. before you get ready to take your shot, push the delete button until the multi-burst icon goes away. this will be represented by what looks like stacked boxes followed by either an H, an L, or a sideways 8 (or infinity symbol). that should solve your taking 2 pictures at once thing.
same problem...how do I delete one picture at a time
