Oven door handle is loose.
SOURCE: door handle
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I recommend that you do not remove the door or hinges to do the job because if it's not aligned exactly, you can have microwave leakage.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: I have a Whirlpool Self
Sounds like you have a defective oven Temperature Sensor Probe.
Let Me know if this helps you out.
SOURCE: door handle
Normally
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your
SOURCE: can't put oven door back on
Hinge has a small hole in it. Lay door flat on rug. Take a pair of channel locks and tension hinge past hole. Put a screw in hole to hold it open. Then put door on product. Remove screws. Thanks, please leave feedback or contact me again for more info if you need it.
