This is a bear of a problem with Transcend owners. You need to use their new Jet Flash format utility. So before doing so, copy everything off your drive to a folder in My Documents. This tool will then format your drive so you can start adding new, more organized data of your choice.
Then, try to remember to keep your data on the pen drive below the 4GB limit. This all has to do with binary math and base 10 math. The drive really doesn't hold 4GB of data, its way lower than that around 3.6GB. So, keep this in mind and keep this format tool around for future use.
I found this download link here, which is dynamic and not static but should work by clicking here.
Should that not work go to this referrer page here. You will have to start by select your product type and then go down through each selection list until you find your model and then the downloads for it will be listed. Click on the Jet Flash utility download eventually.
Personally, I think they could have done this much better and made this way simpler for consumers to find the formatting tool.
Let me know if you run into trouble and if you don't hear from me in 24 hours click on my user name and send me an Ask Me message, I'll get that message and I'll be glad to help you out.
Regards,
Worldvet
SOURCE: How can i remove write protect from my 4 GB transcend pen drive
you can download a software called recovery tool from the transcend website which is exclusively for transcend flash drives.. insert the drive into your system and run the application..
click this link for visiting transcend website..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
you can also try formatting using command mode.
Goto start--> run and type cmd..
the command window will open now . Type format X:
(X being your flash drive)
SOURCE: i have 8 gb trancend pen drive and it is showing
This can be simply removed by changing the position of the write protect lock on the pen drive body. Please refer the figure.
Please come back and rate my solution if turns to be helpful for you or also if you need more clarification.
Thnx :)
SOURCE: 16 gb transcend pen drive write protected
Mine is Zero byte. HP USB Disk Format Utility/ Editing registry / Format from Dos are useless.
