For all Free appliance repair videos visit our VIDEO
TUTORIALS1, If the Bosch fan motorin the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter. To gain access to the BOSCHelement you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the elementyou will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine. 2, If your BOSCH fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your BOSCH oven thermostat 4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timerinto AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Sounds like thermostat faulty, make sure sensor is not detached or broken in oven, if still under 1 year old, then I suggest you contact service agent.
Pleas rate my solution.
Thanks.
