The water dispenser paddle arm/funnel black thing broke (it is plastic) I've tried to glue but no luck, can I replace it, should I call repair man
SOURCE: ge plastic auger ice maker fin broke off cleanly.
Replacement is the best solution as it can fall off and into the ice crusher and end up as small bits of plastic in your drink when you least expect it !! Look at the www.geappliances.com website for repair parts under service and support.
SOURCE: GE TPX24 BRBJ side-by-side drips water from door dispenser
water valve is behind ref.on either the right side or left but you will see your water line going to ref.water valve.Most likely replace.
SOURCE: No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
SOURCE: I replaced the water filter for my GE GSH25JSTA SS
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
SOURCE: Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
