Non si riesce a far riconoscere la camcorder,continua a lampeggiare DV IN
SOURCE: software for the canon zr300 mini dv digital camcorder
You will likely have to order this through Canon.
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
SOURCE: Canon ZR200 mini DV Digital camcorder power is not coming.
First thing, clean your battery contacts, both on the battery, and on the camcorder. Make sure the battery is charged fully (measure it if you have a voltmeter). Make sure your power adapter is putting out voltage (again, measure it if you can) Try a spare battery, if you have one, to make sure the first one isn't just dead. Other than those things, you could have a faulty or broken power switch on the unit. That's about all I can think of offhand.
SOURCE: Canon MVX200i Mini DV Digital Camcorder: Remove the cassette
I got the same problem, does nobody has a solution. Please help!!
Eduard Mendlik
SOURCE: necesito me envien los drivers
Puedes intentar con el Windows Movie Maker. Viene incluido con el Windows XP o puedes decargarlo gratuitamente desde Live.com
