Iomega (33090) 250 GB Hard Drive Logo
Christine Leonardich Posted on Jun 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No Power to External Hard Drive
Have Iomega DHD250 external hard drive. Hardly used. Last used about 4 months ago. Now I can't get the drive's power light to go on. The AC adapter between the power source and the drive has a green light, but not the drive. An adapter problem? A drive problem?
  • 1 more comment
  • tombg Mar 11, 2009
    I have a DHD250GB Hd.   Occasionally gave noise, now the unit does not spin up.   Any ideas how to get the data to another working HD. Can two DHD250 drives swap parts to make one work?
    Need some advice.
  • Anonymous Mar 19, 2014
    I have a the above External Hard Drive but I have lost the users manual and disk if it had one. Can you help me?
  • Anonymous Mar 21, 2014
    After having been a way a month the Iomega 1TB Desktop USB 2.0 Hard Drive simply refuses to start up, he power light blinks, thats all that happens. What can I do?! Apparently the disc isn't spinning ... It has alot of nice stuff, so what do I do?!
A
Anonymous
I have just had a 500Gig External from Iomega do the same. Tested the PSU on another identical drive and worked OK... Must be the drive in my case! Any suggestions warmly welcomed!?!
Kevin Shafer
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Jun 21, 2007
Kevin Shafer
Master
Level 3:
President:
Answers
1314
Questions
Helped
523216
Points
4446
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Iomega 320 external hard drive computer wont recognise
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Trouble Saving to my Iomega External Hard Drive
Some versions of xp like to set permissions excessively, check security settings
1helpful
Iomega large external hard drive doesn't show up on computer desktop. All cables, ports, power source, etc. tested (standard troubleshooting process and testing with other functioning external hard...
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
I bought a iomega external hard drive from future shop a few months ago. I was using windows XP. I recently bought a windows vista. It does not recognize this external hard drive. It is asking for...
do you have a drive for your external hard drive when you bought it? windows vista is very delicate operating system. some manifacture products can't not be recognized by windows vista.
Defragmenting external drive
run the command prompt, by going to start run and entering "cmd" then enter "defrag" followed by the drive letter.  if this doesn't work, enter "defrag /?" with the space for more options
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
