Unfortunately there is no way to narrow the rear spacing on that particular bicycle. 145mm was the intended spacing to use a beefier wheel. If you try to bend the rear triangle yourself you risk several problems:
- not bending either side the same amount leading to a wheel that is not straight inline with the rest of the bicycle
- binding the suspension pivots
- introducing fractures in the rear triangle welds (aluminum is not meant to be bent too much)
- breaking the rear triangle
Your best bet is to find a wheel that fits. Many tandems use 145mm spacing for the rear wheel, or you could find downhill-specific wheels and/or hubs to build up or use.
