Right after the tv is powered on it starts clicking and then shuts down. The power button stays on until I unplug it.
Actually, this problem costed me only $5.00. If you can solder, all you have to do is replace the high voltage capacitors. I replaced the following caps:
C2409: 47uF 160V
C2561: 47uF 160V
C2414: 1000uF 16V
C2417: 1000uF 16V
C2410: 470uF 16V /
25V
C2422: 470uF 16V /
25V
C2473: 100uF 50V
It, worked for me.
Cheers!
IT SOUNDS LIKE YOU HAVE A POWER SUPPLY PROBLEM OR RELAY PROBLEM. BEING A 20 INCH SET IT IS NOT WORTH REPIRING. PARTS AND LABOR WILL BE OVER $100.
