The game freeze then you guys pop up and say that my iPad lost its signal it hasn't lost its signal because i can out and play all the other zynga games I have on my iPad and then when i do go back into play all my chips keep disappearing just a few hours ago I had little over 9 million went out then went back only had little over 6 million now I only have little over 2 million so something is very wrong here
SOURCE: Why does my new iPad get so hot when I play games on it?
Hi Jessica,
Much to your chagrin I bet, there's not too many options besides "play it less" if you want to cool your new iPad down. If the heat is an issue for you now it is probably going to continue to be an issue for you later.
Having said that, there are a couple ways I have used that seems to cool down the iPad by a few degrees:
I hope that helps you out!
SOURCE: How can I improve the battery life of my new iPad? Please help!
Here are two articles that should help you:
http://howto.cnet.com/8301-11310_39-20088870-285/10-ways-to-improve-ipad-battery-life/
http://howto.wired.com/wiki/Improve_Your_iPad's_Battery_Life
Testimonial: "Thanks buddy!"
SOURCE: zynga poker iPad app doesn't open
Double tap the home button on your iPad and try closing the app from the row of apps that will appear at the bottom of the screen. Just press and hold the icon until the red x appears, then you will be able to close the app. Once you have closed it, try restarting the app.
If this does not solve the issue, then I would recommend removing the app from your iPad completely and reinstalling the Zynga Poker App.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
