Programmed a RCA universal remote (using auto code search function) to operate my toshiba dvd/vcr SD-V392 but the menu button doesn't work. all other buttons work.
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
thanks for advice, its the vcr not dvd i'm having problems with. i tried again going through the auto search codes using the one digit brand number to narrow the field. i tried 11 codes and they all gave the same functions --but still no menu. the 11th code actually removed some of the functions i had.. i've tried to re-program remote to at least get back the functions i lost but it isn't happening! i tried removing batteries for a few minutes, turning vcr off and on manually, and nothing.
If you are having problems with it see if you find the "factory default" setting. That should clear anything caused be the new remote! I would suggest a hunt around for an original remote as generally universals are never as good unless you pay lots of money for one. You can also try the Toshiba website they might be able to get you a new remote.
i finally tried the auto code search again and got previous remote functions back -- still no menu. i checked toshiba website but this remote isn\'t listed. i guess vcr\'s are a thing of the past. i don\'t want to buy used because it could go bad at any time. mine only lasted 4 years (whereas my 7 year old panasonic vcr remote was still going strong.) my 2009 RCA universal remote menu button works but other functions don\'t, so i guess i\'ll be using both remotes plus timer record button on original toshiba remote. maybe it\'s time to get a dvr recorder! thanks for your help and merry christmas.
SOURCE: NEED TV CODE TO REPROGRAM MY REMOTE
Hi
Had the same problem but found a similar looking remote for the SDV593SU online and the codes work!
http://tv.manualsonline.com/manuals/mfg/toshiba/sdv593su.html
Cheers!
Michele
SOURCE: Toshiba SD-V280 Remote will not work
This is not a solution it is more a test for your remote. Take a cell phone that takes pictures. Start the picture mode on your phone and point the remote at the camera part of the phone and push a button on the remote. If remote is working you will see it light up on the phone screen. This will let you know if the remote is operating.
SOURCE: What is the universal remote
That would be Harmony universal remote. You can find it in the below link:
http://www.logitech.com/en-us/remotes/universal-remotes
This universal remote control is recommended for your Toshiba SD-1800 DVD player.
Good luck.
RCA
HI,
Direct
Code Entry:
Find the code your
device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX
position, press and release AUX first and then press the device type to be
programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5.
With the device on, press another button to test (volume control/power
button).If it does not work, repeat steps 1 to 5 with other codes which you
have.
follow the below steps
to set remote without codes
Code
Search:
1.
Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX
programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7.
Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below
Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following
information from the drop down list
1.Model of the remote
2.Type of device to which you
want to program(TV/DVD/VCR)
Thank you
RCA
HI,
Direct
Code Entry:
Find the code your
device.
programmed.
5. With the
device on, press another button to test (volume control/power button).If it
does not work, repeat steps 1 to 5 with other codes which you have.
Code
Search:
1. Turn on
programmed.
7. Try using
To Get The Code Please Go To Below Website:
You need to select the following information from the drop down
list
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
thanks. i'll try some other codes and let you know if it works.
