I need installation instructions for a SPS CDC-820 10 CD Changer for my car thanks
SOURCE: my CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
SOURCE: Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
SOURCE: The changer does not detect CDs in it. After
Optical pick up replacement required to rectify this problem
SOURCE: need drawer belt for Yamaha cdc-805 CD changer
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
