All fans work but nothing else happens
Hello the manual and other stuff can be downloaded here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=209#dl
Try to renew the power supply.
Here is a fault finder guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
SOURCE: Need mainboard driver for Biostar Group P4M89-M7A
There are two versions of the -M7A board. Both appear to use the same audio driver in Xp.
http://www.biostar.com.tw/app/en-us/...hp?search=-m7a
There are five versions of the P4M89- board.
http://www.biostar.com.tw/app/en-us/...p?search=P4M89
You need to determine the exact model you have. Biostar has been known to make custom model numbers that do not show up on there site. But the drivers for one of these boards should work for your computer.
If that fails, try the generic Realtec drivers of this page.
Download the one for Xp.
http://www.realtek.com.tw/downloads/...&GetDown=false
SOURCE: need mainboard driver biostar p4m800-m7a
What I have, my problem is not the driver mb biostar p4m890-m7a V1. if I can get it. if you can please send to my e-mail [email protected]
SOURCE: can biostar k8m800 m7a 754 run windows 7
The processor will run windows 7 but may not be very fast.
Look for the correct driver for the m/b at BIOSTAR.com
SOURCE: i have a biostar p4m90-m7a mobo i installed 4gbs
i think u r using windows 32bit version thek can support only 4GB of memory,And memory includer grafix card ,ram motherboart etc so other 1.5GB is used by other hardware in your pc
SOURCE: Problem with Biostar P4M800-M7A Motherboard
I had exactly the same problem.... waste hours on it. I solved it by clearing the CMOS. Pins 1 and 2 on JCMOS1 are closed in normal operation mode. Move the jumper to pins 2 and 3. I then pressed the power button a few times (the motherboard will not respond to the power button at all when it is configured to reset the CMOS), but I don't think pressing the power button is neccessary. After about 30 seconds, put the jumper back on pins 1 and 2, and power up. When I did this the motherboard responded finally. Hope it helps! :D
