How to remove broken off needle from pfaff machine why is bobbin not working
Where is the broken needle stuck? The broken upper part should just come out like a regular needle (via the needle-screw). If the broken tip is stuck, try removing the bobbin case from the machine. When that is released, everything under the needleplate should be accessible.
If the needle is hitting, most likely your machine has been knocked out of time (which frequently occurs when the needle strikes something it shouldn't). Search for sewing machine timing or take it for service.
