20 Most Recent
Singer 1507 Questions & Answers
New Singer 1507, thread loose and tangled on bottom side
If you are getting a thread mess under the fabric, it is a top thread problem.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Retest your machine and tweak the tension, if needed.
2/27/2018 4:05:32 AM •
Singer 1507
Answered
on Feb 27, 2018
Looping thread under fabric
Yep, it's generally user error. The top thread is not seated completely in the tension disk.
Remove the top thread from the machine.
Hopefully, all the adjustments you've made to the machine can be reversed because bobbin adjustments can be difficult to undo.
2/19/2018 2:25:46 AM •
Singer 1507
Answered
on Feb 19, 2018
New Singer 1507- handwheel is stuck.
The bobbin might have a bunch of thread off it inside the compartment here the bobbin is. Also, make sure it's thread correctly, that can goof things up to.
6/16/2017 7:22:26 AM •
Singer 1507
Answered
on Jun 16, 2017
How to oil my machine singer 1507
Follow the instructions in the owner's manual. Computerized machines do not require the extensive oiling that older mechanical machines need. Be sure to use the correct oil for your machine.
10/11/2016 2:32:53 PM •
Singer 1507
Answered
on Oct 11, 2016
Hand wheel & needle very stiff
Hai, I think your machine timing is changed. So you can't sewing properly. Please check the timing and put the oil everyday all oil parts properly.
2/17/2016 9:59:37 PM •
Singer 1507
Answered
on Feb 17, 2016
The machine's needle doesn't move
see user manuals check all wire and conect. if engine is running and turns
the pulley and the pin is still trying to tighten the pulley nut on pulley.if belt pulleys or manually by turning the needle does not move then may exist mechanical failure....
7/7/2015 6:26:10 AM •
Singer 1507
Answered
on Jul 07, 2015
Why doesn't it feed
Check the feeders if they are locked in the down position, it won't feed.
3/13/2015 3:06:06 AM •
Singer 1507
Answered
on Mar 13, 2015
