Just bought this canon sx 260. It shows I can change the shutter speed t when I get to it I can not figure out how to change it. I thought it would be the function set, but I can not figure it out.
For direct control over the shutter speed, set your camera to the Tv (time value) mode. See the "Specific Shutter Speeds (Tv Mode)" section in the user guide (page 140 in my copy).
If you need the user guide, you may download a copy from here.
SOURCE: canon sd 550 (and sd 200) shutter speed
If you check out a review site such as www.steves digi cams. com or even the Canon site to check out the spec of the camera to discover what shutter speeds are available. When shooting fast moving subjects try panning the camera on the object as you press the release this will[to a degree] keep the primary image sharp[ish] whilst blurring the background
SOURCE: Manually setting shutter speed and aperture..
http://web.canon.jp/imaging/eosd/eosdigital4/specifications.html
First off, welcome to the world of photography! Good luck and have fun!!!
Like any slr, you have the option of Manual exposure. I'm not familiar w/ modern Canons (I use Nikon). According to this page, however, you also have aperture priority and shutter priority. I'm pretty sure ALL modern Canons have bracketing modes as well (Use this for HDR).
I couldn't find the 450 manual (I'm assuming Canon's web devs are behind), but I did find the instruction manual for the 400 :
http://gdlp01.c-wss.com/gds/0900000357/EOSDRXTi400DIM-EN.pdf
Should be similar, probably w/o some of the functions. Although you SHOULD have a book w/ your camera ;). Read it thoroughly.
Ok, according to the 400 manual, put your camera into Manual mode, then adjust the regular dial to adjust shutter speed. Then, to adjust aperture, hold in the A/V button while you adjust the same dial.
Like I said, may be a bit different. I think the dial may even be digital buttons rather than analog...
hope this helps!!!
SOURCE: I lost Canon Rebel XTi
Hi
Click on the following link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=14256
Kind regards
BearWeb
SOURCE: I can't figure out how to set the self timer from
For the SX 110 IS 9 mp camera: With the camera in picture taking mode, Hold the bottom of the roller dial down at the point closet to the timer icon. Hold it for a couple seconds, then the screen will display the timer settings. Select the setting you want and start taking pictures.
SOURCE: Apperture and shutter speed settings
First select AV (Aperture Mode) to select the required aperture then switch to M (Manual Mode) and spin the wheel until you get the right speed.
Spurs34
