Wont stop filling up with water, won't rinse or spin
SOURCE: Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
SOURCE: We have a GE top load washer with the model number
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling into the washer, then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. Also, the pressure supply tube connected to water level/pressure switch may have a hole in it or a bad connection, or possibly plugged up. This rubber tube must have an airtight seal at both ends to perform properly. be sure to check this item also. Happy to help, Tim.
SOURCE: washer will not spin out water but turns during wash cycle
Try cleaning out the trap. It is located under the door and can be accessed be removing three screws at the base in the very front of the washer. The trap is white and screws to open. Watch out though, because if the washer is full of water it will come spilling out! With the trap removed, you should also use your finger to feel the opening of the pump to the side. I found a few bobby pins in my pump, and once they were removed it worked again!.
SOURCE: GE WDSR2120J wash cycle sound
It's possible that the tub suspension system is out of position. Open the cabinet top (use a thin putty knife in each front corner to release a spring clip) and watch the mechanism while washing. Try shaking the assembly to see if you can spot something rubbing. Hope this helps!
Testimonial: "Quick response with clear verbose guidance. Thank you so much :)"
SOURCE: No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
