My Hitachi SR-2000 receiver's right speaker connection does not work for either the main or remote speaker option. Both speakers work fine on the left speaker connection but when connected to the right it produces no sound. I know it is old but would you happen to know what the issue is and if it can be fixed? Thanks.
SOURCE: hitachi sr 2000 right speaker interference and no sound
This should be a relatively simple repair. The outputs for the right side could be out, but more likely, the switches and controls may need a good cleaning. Typically you can expect a labor rate in the $80-$100 range. If the channel is out, the parts cost could be between $15-$40.
If you can indicate your location, I may be able to suggest a shop.
Thanks,
Dan
Testimonial: "thanks a ton...I am in South Carolina. Do you know anything about the light source for the power switch? Is there a tiny bulb that can be replaced?"
