Dishwashers Logo
A
Anonymous Posted on Mar 07, 2018
Whirlpool gold quiet partner iii was making humming noise. I took apart and found a couple of rubber and a plastic straw. Thinking I had it fixed, I ran a cycle. It started fine, however it stops using water. Same with rinse cycle. Sometimes it works, sometimes it doesn't.
Level 3:
  • Whirlpool Master 19,187 Answers
  • Posted on Mar 07, 2018
Whirlpool Master
Level 3:
Answers
19187
Questions
0
Helped
4346444
Points
82261
We need to know the exact model number of the machine and you need to tell us what you mean by take it apart.
5 Related Answers
Anonymous
  • Posted on Oct 13, 2008
SOURCE: whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Anonymous
  • 311 Answers
  • Posted on Jan 12, 2009
SOURCE: Whirlpool gold Quiet Partner III is really loud.
now you'll be able too hear under the tub if motor bearing was the noise.put a long tool to the motor and close to you ear,see if that gives you a clue[i don't want you to give up on it if its not the motor]if was to buy that motor wholesale it would be around 50 bucks or so ,retail about 100 or so.so if replacing depends on the shape of the rest of the unit.[i have sold and installed many]new dishwasher on sale 300$ or so,plus your time to install.but if new its a forsure thing.so depends how much motor,how sure you are wiill solve problem,what shape unit in.hope that helps. God bless ,tom
Anonymous
  • Posted on Nov 17, 2009
SOURCE: Cannot unscrew cap on rinse aid compartment in door of Whirlpool Gold Quiet Partner III
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
Anonymous
  • 311 Answers
  • Posted on May 28, 2010
SOURCE: My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
Anonymous
  • 262 Answers
  • Posted on Mar 01, 2011
SOURCE: My Whirlpool Gold,quiet partner 3,model
On a "normal wash cycle"
turn all the spray arms at the 12 o'clock position.
Please answer the folling questions.
Will water enter the unit?
After water has stopped entering the unit can you hear the wash cycle start? The wash pump on? and water being sprayed?
Now open the door and see if the spray arms have moved.
Reading what you have posted I just want to make sure that there is never a wash cycle running.
Please post answers.
Thank
Keith
Whirlpool gold quiet partner iii soak and scour indicator light on won't start
Es posible que la luz Soak & Clean del lavavajillas Whirlpool Gold Quiet Partner III no se encienda si el lavavajillas no est? recibiendo energ?a o si el lavavajillas no est? en el ciclo correcto. Se recomienda verificar la fuente de alimentaci?n y asegurarse de que el lavavajillas est? enchufado y reciba energ?a. Si la alimentaci?n est? conectada y el lavavajillas est? en el ciclo correcto, entonces es posible que haya un problema con los circuitos o el cableado del lavavajillas. Se recomienda ponerse en contacto con un centro de servicio autorizado de Whirlpool para obtener m?s ayuda.
1helpful
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
2helpful
10helpful
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 • Dishwashers
1helpful
Our Whirlpool makes a howling noise
Hello-  Debris in sump can cause noise, but if unit is 5yrs or older, motor bearings are failing. Part about 100$. Have installation instructions if needed. Let me know if this info helps -have more if needed. -Thanks-ED
Whirlpool gold quiet partner iii bearing noise
if its noisy when washing check chopper assembly. if its ok change the sump pump assembly
1helpful
4helpful
2answers
Jul 08, 2008 • Dishwashers
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
