Washing Machines Logo
Anonymous Posted on Nov 22, 2012
Maytag top loader belts sometimes comes off in spin cycle. Can the tension be adjusted?
The machine will still wash and drain, just not spin when it happens. Do I need a belt or can I adjust the tension, maybe?
Richard Roth
Level 3:
Top Expert:
  • Maytag Master 9,472 Answers
  • Posted on Nov 22, 2012
Richard Roth
Maytag Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629045
Points
28464
What is the model number of your unit?
5 Related Answers
Jimster
James Greene
  • 240 Answers
  • Posted on Sep 09, 2007
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
A
Anonymous
  • Posted on Apr 24, 2008
SOURCE: Maytag LAT9356AAE drive pulley stuck during spin cycle
I had the same problem called a repair guy who told me the transmission is ceased up and the main bearing and seal is shot. Told me that Maytag uses defective parts in their machines and recommended direct-drive washer. Repair would cost more than to buy new. Sorry!
Anonymous
  • 481 Answers
  • Posted on Jun 29, 2008
SOURCE: How do you know if
  • tilt the machine over and look at the bottom. the belt is there.
  • it will feel loose but that is normal. it is spring tensioned.
  • the noise is probably coming from the water pump, when they are bad they make a loud noise.
  •  turn the pulley around a couple times to see where the noise is coming from.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 08, 2008
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Anonymous
  • 530 Answers
  • Posted on Jun 10, 2009
SOURCE: How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
Maytag top loader will not drain all the water out of cloth during the spin cycle
belt tensioner idler pulley out of adjustment or damaged. or belt is worn out. belt is at bottom of machine and if you remove lower front cover, you can run the machine through a cycle and see the problem. my pulley fell off the shaft was on the ground and I had to replace the assembly.
1helpful
2answers
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Washer will not spin during the spin cycle clothes still very wet
If it is belt drive and top loader check tension on belt drive
Maytag top loader won't do the wash cycle
hate to be bearer of bad news, but the transmission is the culprit this time.
How do you know if your belt is not functioning properly? During the wash and spin cycles the machine makes an outrageous noise. The washing machine is 7 years old, a Maytag Performa, Top Loader, Model #...
2answers
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Washing machine spin cycle
chances are the pump may have something in it or the drain line is kinked a little front loader machines have a clean out on the pump that you can get to buy taking the lower front panel off.top loaders you have to pull access cover in the rear and pull hose off and check for blockage also check belt tension and quality of belt
Belt stops running and clicky noises
If this is top loader the gearbox is faulty. Regards Advisor
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
