Change the channel on them
Here is a link to the user guide for the XTN style radio. http://www.123radios.com/manuals/xtnmanual.pdf
Programming instructions begin on page 18. You will need to set the frequency and interference eliminator code (PL code) the same on all the radios.
When you enter programming mode, you can use the menu button to walk you through the various options you can program.
Best regards.
SOURCE: motorola walkie
With the radio turned off, hold in the PTT and the Monitor button at the same time. Continue to hold these in while turning the radio on. Wait for the radio to finish making sounds before releasing the PTT and monitor button. Then simply press the menu button to walk through programming each of the features. When you have reached the end of the user programmable features you will notice the radio has a different chirp to signal you are done. Then simply turn off the radio to leave programming mode.
SOURCE: motorola xtn series radios
Here is the link you need: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
