Strings buzzing can either be the action being set too low, or the frets needing dressing or the neck not having enough relief or being actually warped. We can't tell from here.
Learn how to adjust the truss rod in your guitar, if you can. That's the easiest fix that does not involve specialized tools, filing frets, or disassembly. You may need to buy or borrow a long hex driver to reach the truss rod adjusting nut https://www.youtube.com/watch?v=xyqrSRI2asc&feature=youtu.be&list=UUM-CsUeK57J8grv9BSBRRhQ
If it is a simple relief problem, that may fix it.
Adjusting the height of the bridge requires taking out the bridge and shimming it, which involves some woodworking skills (unlike an electric guitar where you can adjust bridge height and intonation with screwdrivers and or hex wrenches)
This should be possible to fix, depending on the cause, but because this is an acoustic guitar adjusting the action, frets and any major neck issues is a job that should be looked at by a qualified person. Keep in mind that your Alvarez is not a hugely valuable guitar, so you want to set a budget and get an estimate.
If you are not an experienced repairman and your guitar has any value, take it to a competent repairman to get it done correctly.
That said, here are some links to how it's done-
You should take teh guitar to a Luthier at a guitar repair facility. Either the frets are worn (visible) or possibly the truss rod needs adjusting. Both of these need a bit of proffessional attention. It sounds like your particular condition is probably the truss rod... also are you using the CORRECT tension strings for the instrument? Wrong or worn strings can be the problem!
The problem MIGHT be with the guitar and this amp may be capable of presenting the sound from the guitar. Put a "fake fret" on the guitar... a piece of coathanger wire laid by the offending fret that will slightly raise the string for a test. Does it still buzz with the strings slightly higher, but at same tone... Note you might have to tune the strings SLIGHTLY with this fake fret to get on exactly the same pitch as using the normal fret... If the amp still buzzes with teh strings in no way creating the buzz, the problem is likely something in the cabinetry or chassis that is resonating at that pitch.
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks.
1. Intonation problems can be due to worn strings even if the guitar is set up properly. New Strings can fix this. This is the most common problem.
2. Also, changing string size may effect your set up too. Typically, new guitars come with lighter strings such as (9's) which the guitar is set up for. The positive is that 9's fret easily. The negative is that they bend too easily for some players who either slightly bend them when chording (accidentally), or press too hard on guitars with jumbo sized frets, which in turn bends the string toward the fret board causing detuning. To fix these items folks may suggest you get a heavier string like a (10), but the problem can often be solved by playing with a lighter hand, pressing only enough to make contact with the fret and not pressing the string all the way to the fretboard. Check your intonation using this light touch method and see if it's okay verses pressing the string all the way to the fretboard. If the intonation is okay with the light touch, the guitar intonation is set up properly. You may want to consider playing with a lighter hand or getting a guitar without jumbo frets such as Fender strats etc...
Putting a heavier string on a guitar set up for (9's) would likely cause the buzzing that wasn't there before. In this case you'd need the guitar and neck set up again to accomodate the 10's. So decide what size string you want and set the guitar up for that size.
These considerations are true for any electric guitars.
After consideration of all of the above, you still feel it's the guitar, I suggest you push for a replacement or perhaps credit toward another guitar.
The frets MAY be worn or the neck truss rod MAY need adjustment, Neither of these is DIY unless yiu have experience in repoairing guitars. Since this is only on the 2nd string, inspect the frets for wear and the only DIY thing to try is to replace that string... DO that first !!!
Hello Have a look at the neck part where the strings move through that aligning unit which has the 6 slits cut into it where the strings goes through at the top of the guitar neck.
What usually happens, the slits get worked out, thus the strings move fractions closer to the fret board which will result in a muffled sound if you press down on the string you get a fret buzz. This happens when the string touches the fret board on more than one spot.
When you play a solo you can get a muffled sound out of certain strings. This happened to me, i just replaced this unit, very cheap, and all was fixed. Hope this can work.
