20 Most Recent
Fender Deluxe Active Jazz Bass Electric Bass Guitar Questions & Answers
Fender serial number look up
Your guitar was made at the
Fuji-gen Plant (for Fender Japan), Japan
in the Year(s): 1994 - 1995
- via guitardaterproject.org
7405109a
1976 -77 it depends on originality and condition a store will give less for resale private buyers are better but it must be 100% on both orig/condition in the 2000's
Serial number on a jazz bass ?
Check front of headstock, rear of headstock. Neckplate on the back of guitar. If not, remove neck and check the heel and neck "pocket."
I have a Fender Deluxe Active Jazz Bass thats
This sounds like either a bad guitar cable or a bad jack in the guitar. Possibly your friend is not as qualified to find these intermittent problems as needed? These jacks are really junky and often have riveting of the barrel come undone... especially if the retaining nut is overtightened. The LONG barrel like jacks are notorious for failing. You have all the information you need to solve this problem. First try a different guitar cable... (often they are broken or intermittent at the end where they flex). If that doesn't fix it, replace the jack in the guitar. Also verify that the conductive coating paint within the guitar is grounded. Sometimes the contact to it is destroyed when the volume control shafts or jacks become loose and they depend upon the shaft barrel to ground the paint.
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
12/15/2023 7:48:03 PM •
Fender Music
Answered
on Dec 15, 2023
How can i control 2 different fender hot rod deluxe 3's drive channels with just 1 footswitch? Thank you in advance
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience.
I recommend the Fender single button footswitch for this use - Type: Footswitch
Number of Footswitch Buttons: 1
Manufacturer Part Number: 0994052000
It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
11/22/2022 1:29:51 PM •
Fender Music
Answered
on Nov 22, 2022
Guitar amp input not working
Get inside it and check the connections to the plug especially any shielding / braiding. Resolder the connections.
4/17/2022 3:41:52 PM •
Fender Music
Answered
on Apr 17, 2022
