The MS-1446SQP is the version of this microwave sold in Mexico. To set the clock, press the button labeled Parrar/Borrar (Stop/Clear on English microwaves) in case any cooking programs are running. Then press the button with the clock face (Reloj). Then press the touch pad labeled Inicio/Inicio Rapido (Start/Fast Start). Type in the 4 digits of the current time (24 hour format). Then press Inicio again. (Note: I have left off the accents.)
The manual for the LG MS-1446SQP is available here: http://www.lg.com/mx/soporte-producto/lg-MS-1446SQP . The directions for setting the clock are on page 12 (pictures of the control pad are included). This is the Spanish version of the manual and is a pdf. Thus you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
On some microwaves, the English equivalent to the Inicio button is probably Cook/Fast Cook. If you have problems with the touch pads responding, check if you have enabled the Child Lock feature. To toggle the lock on and off, press and hold the Parrar/Borrar button for 4+ seconds. Bloqueado will appear (and 2 beeps will sound) or disappear on the display. Cindy Wells
SOURCE: I have an LG Intellowave
Push button that says 'clock' then use the '10min' button to set hour, '1min' to set 10 minute intervals, then '10sec' button to set minutes. Click 'clock' button again to save. The trick is to make sure the the colon like dot separator on the clock is flashing when you try to make changes. Did my head in working this out... in the end I had to ask my wife...
SOURCE: can't set the Clock on microwave
One of these combinations may work:
CLOCK > 1
> 2 > 3 > CLOCK
CLOCK > 1
> 2 > 3 > START
CLOCK > CLEAR
> 1 > 2 > 3 > CLOCK
CLOCK > CLEAR
> 1 > 2 > 3 > START
Otherwise, I would contact the dealer you bought it form to see if they have a number for Cascade.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
SOURCE: Need instructions on how to
you press clock ,then clear, enter the time in 12h format! ( 24h format does not work) then press clock again :o)
