Not sure. But after reading all the reviews I have found I'm returning it today.Not sure. But after reading all the reviews I have found I'm returning it today.
yes the blue light is on,but when i go to turn it on nothing happen need answersyes the blue light is on,but when i go to turn it on nothing happen need answers
You can't post conmments that contain an email address.
I had same problem—I just removed/plugged back in hdmi cables and it came back on! It was just a lose connection—I was terrified of an unexpected out of budget tv that I can’t afford to buy—posting this to help out anyone who may or has this issue—it’s a 9 series mind blowing tv
It could be the temp sensor going bad. This sensor sits on top of the
metal housing which the bulb assembly slides into. The bulb assembly
will have a hole on top and this is where the sensor is above. There is a
small blue and white wire that plugs into it. If you pull the wire out
and put a paper clip or wire in the coupling you will basically bypass
the sensor connecting the blue and white wire. If your tv turns on then
that is your problem. Its cheap too. Here were my symptoms..1] Turn tv
on 2] Bulb would light up..(which eliminates the ballast) regular
picture would show up (which eliminates the bulb and color wheel) 3] 30
seconds later tv would shut down with 3 flashing lights. After bypass
the tv turned on as always and hasnt shut down yet. Always un plug tv
first. Get the replacement part to avoid overheating and possible fire
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
Sounds like it could be the remote sensor in the set but a look at the data line comming out of the sensor with a scope would tell ya if thats so.. Thney are the omnly ones to fix an rca in your area as its still under a warranty and you can take it anywhere thats authorized for rca unless you bought it as is and if you did you should have tested the whole set.
