Panasonic SC-HT740 System Logo
neila porter Posted on Oct 28, 2012
Wiring sound system
How do i wire for sound
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
I have a cable controller connected to a Bose sound system and a Haier 32 " flat screen TV. Everything works great until I want to view a DVD, then all I can hear is cable audio with the DVD video. How do...
That sounds like a miss-wired setup. I would unplug the wires and re-wire it making sure the right wires are in the right holes. Sounds to me that the DVD audio is not going to the bose and only the TV audio is.
How to connect my JVC Audio/video control receiver digital surround sound system
Need to know how to set up a surround sound system? It's fairly easy, with the right equipment. Surround sound gives you that "theater" feel in your own home.
For more information on optimizing the sound of your chosen system visit:
http://www.ehow.com/how_3393_set-surround-sound.html.
To set up a surround sound system go to:
http://forum.ecoustics.com/bbs/messages/34579/219978.html.
Additionally,Some people prefers a wire diagram to connect their surround sound system. The basic concept to connect any audio system is to follow the path of sound from its origin to its final output stage, either headphones or speakers. There are other basic premises to follow, such as the impedance of the speakers and the output of the amplifier, but the concept is to start with an input and terminate each input to an output somewhere on the amplifier unit.
A wire diagram shows a picture that represents where each of these wires would go in considerably little detail. One example would be that a television set starts with a signal from somewhere, broadcast or cable, and comes out of that antenna and goes into the surround sound amplifier. The sound is processed in some way and the video is output to the television set and the audio is output to the speakers or headphones. Although complicated in textual from, most find that a wire diagram is much easier to follow.
For an example of a wire diagram for a surround sound system visit ..
http://www.crutchfield.com/.
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
How to replace sound system
You could replace the sound system with a stock, I assume you want to upgrade. You would have to bypass the entire old systems series of electronic functions, and start with installation of the new radio, running power to it, running either the old speaker system or upgrade to something you want and hard wire it with the proper sized wires, determined by the amperage draw on the system and the length of the wire.
I hope this helps.
My two year old put sixteen cents in my CD player. I have gotten the change out however my stero sound is not working right. I got upset and hit the steering wheel and the sound worked for a short period...
reset the stereo by pulling the fuse it sounds like it just needs reset sounds like also check the wiring on back of stereo make sure no wires came unpluged loose theres 2 power wires red and yellow 8 speaker wires 1 ground wires black
1helpful
2answers
Wiring diagram for sound system
I cannot copy and paste wiring diagrams from my online resource.
However, if you have the harness adapter for adding an aftermarket radio to your vehicle, the wires are all labeled for easy installation of most if not all aftermarket radios.
Is that what you want to do?
Try BestBuy or Ebay.com for getting a harness adapter that plugs into your wiring to get the proper labelings.
Wiring assignment for plug of Panasonic SB WA340
my woofer lost the sound I.C how can i solve this problem?
Wat do i need 2 install a sound system
You can go to your local car audio store, Walmart, Circuit City and buy a Wiring Kit they go by the size of your amps ( Watts ) you can get them fairly cheap and it comes with all the wires, and fuses needed.
I hope this helps answer your question. This is the best way really to get the right cables (makes the system sound better with proper wiring) The power cable has the fuse built in as well. Feel free to leave positive feedback if this helps.
2answers
Extension speaker wire
Radio Shack is you're best bet. They have several different types of speaker wire. That is where I get most of my audio and video supplies.
2answers
Pretty colors
Sounds like the other DVD player went bonkers. Try unplugging power on the DVD player you were playing the game on for 5 minutes, then plug it back in.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
