Dell XPS 15z Computer Intel Core i72620M processor 270 GHz with Turbo Boost 20 up to 34 PC Notebook Logo
Posted on Oct 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell xps beep hard drive not found
Ran a diagnostic, told me hard drive was missing. Everything else was fine. Dell xps 15.
Anonymous
Level 3:
  • Dell Master 6,771 Answers
  • Posted on Oct 27, 2012
Anonymous
Dell Master
Level 3:
Answers
6771
Questions
0
Helped
1779425
Points
21413
The hard drive may be malfunctioning, remove hardware and reseat back in place, if no change have it checked for possible replacement.
5 Related Answers
proton77
Mandeep Singh
  • 1184 Answers
  • Posted on Jun 16, 2008
SOURCE: Dell Inspiron 6000
The short DST test is generally the failure of the HDD,It would giive you code next to it , that would something like 1000-0146,or 1000-0141 etc. Do give that code and I would let you know the exact failure
Thanks
mandeep
Anonymous
  • 10 Answers
  • Posted on May 21, 2009
SOURCE: Dell Xps M1210 Web Cam Driver missing
Mail the maker or costomer assistance and pleas send me more info at [email protected]
Anonymous
  • 24 Answers
  • Posted on Oct 08, 2009
SOURCE: Dell XPS M2010 Starting Problems
Ok. Here is the thing. I hope everybody sold their problem, but I will just post for others who may experience the same thing.
1st believe it or not : there is nothing wrong with motherboard, as when you press the power button, computer will shut down. with defective motherboard it will just continue running untill you will unplug it.
2nd believe it or not : it can not be battery issue or hard drive issue, because it does not make any scenes in any way. I have to agree that hard drive on the right is semi-correct answer.
REASON:
IT is video card that messing up everything. And it is located right under right hard drive. That's why when somebody removed hard drive he/she accidentally corrected the cooling system of video card , which returned M2010 to live.
CONFIRMATION:
1. First remove the top cover from the computer. There are 2 sides the plastic things. If you look at the back of your laptop you will see 2 small holes , one on every edge of the back. You stick something there it will loose the front cover.
2. unscrew all the screws hat have ">" or "<" signs next to them. there are something about 15-16 screws in total: this will allow you to open the cover under wich you can find the motherboard and stuff. When you open the cover pry to start the computer, and you will see that fans will not start even after 1-2 minutes after you hit the power button.
3. Remove the right hard drive and under it you will find screws A, B, C, D (silver) and also 1,2,3,4 (black) unscrew the black ones first, them remove video card with the cooling mechanism. now try to turn on the machine. you can see that after like 20-30 seconds fans start working which means that motherboard is fine and it was the video card that was giving problems.
SOLUTION:
1. I am not sure what causes the issue but I have fixed it this way:
uscrew silver screws and disconnect cooling part from the actual video card.
2. clean both, video card and cooling system not touching sky blue foam ICs. That staff is needed to cool the chips on the video card.
3. let them dry for an hour or so after cleening, than apply some Thermal compound, thermal paste and re assemble the video card with the cooling staff. (mek sure no screw is loose or something)
4. put it back and turn on the computer. If it works , whell .. it works now :)
if not then either you levae some liquid on the video card or screws are loose. try to play a bit with screws. but my personal suggestion is just to wait for a minute or two until video card gets hot and fixes liquid problems itself :)
Try it. It worked for me perfectly ...
Anonymous
  • Posted on Dec 10, 2009
SOURCE: my dell xps m1330 will not boot up.it comes up on
my dell m1330, don`t boot up black screen thats all :(
[email protected]
Anonymous
  • 132 Answers
  • Posted on Feb 21, 2010
SOURCE: My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Dell XPS M1210 Stuck on blue screen due to hard drive
To determine if your hard drive is bad or good, run the Dell diagnostics.
Here is a link for the owner's manual of your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1210_owner%27s%20manual_en-us.pdf
Dell xps 15 error 2000-0146 locks on dell startup screen have to do hard boot ran 64 bit diag, read failed. I had just transferred around 2 years worth of pictures to one location (hard drive) when th
with os disk in dvd drive. try system repair, You can do this by tapping rapidly on the F12 key at the Dell Splash screen when the system starts up and choose the CD/DVD drive from the Boot Once Menu that appears. You can tap rapidly on the F8 key when the System starts up and select the repair your computer if it works and windows boots transfer pictures to another computer. only run the bad hard drive for a long as needed to get recover your pictures
Dell Vostro 1500 Laptop: Without any obvious warning, my laptop will no longer boot into windows vista beyond the "microsoft corporation" screen with the green progress bar. it will get past the...
@rkbrown1_rb
If your Dell diagnostics shows no fault on the hardware (hdd, memory, chipset, videocard, etc.) but still same issue occurs, I recommend doing another test using a different utility. Try using Hiren's Boot CD that can be found here and try running the S&M Stress Test 1.9.1 and Video Memory Stress Test 1.7.116. If your computer hangs while doing the stress tests, the video card or CPU might be failing already.
Good Luck.
I reached capacity on my 220 gb hard drive. Got a 750 gb drive, copied my old one to it via acronis and replaced the old drive. Turned on laptop and got Dell diagnostics. When I exit diagnostics screen...
Unfortunately you cannot replace drives in that manner. The 2 drives are completely different and when you mirrored the smaller to the larger, your system does not recognize the drive because it is effectively not formatted or partitioned properly. The process you used would work between 2 drives of the same size and model, but not between 2 different drives.
Your best choice to to do a clean install of the OS on to the new drive, get everything installed and updated, and then transfer the important data ONLY from the old drive to the new.
Error code 0141 internal hard drive not found
It can be a possible hardware issue or a software issue
Try to run the dell diagnostics
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If it fails replace the part on which it fails.. If it passes reinstall the OS to fix the issue
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
So I recently found out that my hard drive is failing since any time I try to play a game my computer shuts off and when I ran a Diagnostics test it stated I had the problem 0146-2000(My computer is a Dell...
May be your graphics card is not supporting the game. Please ensure you've enough space in your C drive, where the game is installed, and increase your virtual memory. Make sure your graphics card supports the game. Now there shouldnt be no problem.
Thanks, hope i've helped you.
Dell Repeatedly Restarting in a cycle
Hi ,
Do you have an Antivirus installed , if yes kindly scan the drive , It happens also due to virus in your PC .
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
