When i switch my camera on its blurry even when i take a photo. could you please suggest anything to fix the issue. i do not have my booklet that came with it.
There are many aspects that cause blurry photos:
1. Shutter speed is slow.
2. Subject is out of focus.
3. Aperture is not suitable.
4. The subject is shaking or moving.
5. Failed to hold the camera steady when shooting.
If you want to make photos stable, you can correct the above mistakes. If you want to fix blurry photos, you have to use some tools. Read on this tutorial to learn more: https://www.leawo.org/tutorial/how-to-fix-blurry-photos-1409.html?fixya=1409
Use a tripod or set your camera to a higher shutter speed.
SOURCE: Auto Focus Not Working
Mine did the exact same thing and i hav only had it for 3 months; there is nothing i could do exept for taking it to the professionals
SOURCE: My camera will not take photos
'I have opened the camera up and looks OK' How can you tell? what you have done is negated any chance of as repair or replacement. But a new camera?
SOURCE: My camera is blurry..and it takes blurry pictures..How can i fix this?
some camera's require you to hold down the shtter button half way to focus. sometime setting get messed up also, make sure it is set to automatic in the set up menu
SOURCE: my camera says card locked
Check the side of your media device, it will be locke.
See pic: http://en.wikipedia.org/wiki/Image:SD_Cards.png
Slide the little switch to the unlock position.
SOURCE: it takes so long to process after I take a photo,
The Samsung L730 is Intelligent LCD brightness,it automatically detects environmental illumination and adjusts LCD brightness for optimal image viewing. no problem it just working fine
Testimonial: "Thanks :) I guess I just need a new camera then....it takes up to 2mins to process and the photos that take the longest are not of great quality"
