CODE: 0572014 IMEI 354847/01/5788
SOURCE: nokia 6110 unlock code
Hi, willimina your IMEI: 354847011991730
mastercode:
764454375x
The mastercode can be entered instead of standard security code.
and
Hi, LucasMok your IMEI: 357666019013793
mastercode:
461072065x
and the other users please let me know your IMIE number for unlock any phone.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
SOURCE: SIM card not valid
Hi thee, I list here the possible reasons for "Sim card not valid"
1 - The phone is locked to a different network. In this case the phone usually accept the sim card the same , and has no network, but sometimes it may return the error message. Unlock the phone at a local shop.
2 - the SIM card is faulty. Test the card on a different phone to find out.
3 - The phone is faulty. Test the phone with different Sim cards, if the Phone returns same error on all cards, then the phone is faulty.
SOURCE: want to copy all contacts to sim card
To copy a phone, fax, or pager number from contacts to your SIM card, scroll to
the contact you want to copy, and select Options > Copy > To SIM directory.
SOURCE: sim card not valid
Friend i have same cell phone and i am also facing this problem but dont worry
go to network menu and select Automatic network that problem will be solved if not them show it in to nokia care
SOURCE: Need unlock code for Nokia
Get your phone IMEI number which is a fifteen digits number located in the battery compartment of your phone.
Then Visit http://www.nokiamastercode.com
Input the imei number at the site to generate a master reset code which you input when you switch on your phone.
This enables you to reset your phone security code.
Rate this fixya. Good luck.....
