20 Most Recent
Nokia 6110 Cellular Phone Questions & Answers
Want to copy all contacts to sim card
To copy a phone, fax, or pager number from contacts to your SIM card, scroll to
the contact you want to copy, and select Options > Copy > To SIM directory.
Find puk code
Hi you can find your puk code on the pice of plastic which come with SIM card or obtain it from your mobile provider.
Nokia 6110 unlock code
Hi, willimina your IMEI: 354847011991730
mastercode:
764454375x
The mastercode can be entered instead of standard security code.
and
Hi, LucasMok your IMEI: 357666019013793
mastercode:
461072065x
and the other users please let me know your IMIE number for unlock any phone.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
Hi ! Brother my nokia6110
look up nokia mastercode ,or type this link in your search bar ( http://www.nokiamastercode.com/mastercode.php )
Unable to remove certain
This is what to do. copy all the information on the memory into another memory after which you will now format the memory card and return the information back on it.
Formatting the memory card will remove the java software.
Regards
Security code nokia 6110
sasak_twolan,
please try below commands:
*#7328748263373738# resets security code.
Default security code is 12345
hope this helps
Nokia 6110 Navigator
In Singapore, phone
please check that whether it happens when you don,t have memory card in it.
What you must do is to take a backup of ll your data and then you should do a hard reset using the procedure below.
1.- Basic Reset or Soft Reset for nokia 6110 Navigator
This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) or applications from
a third party. Key Code *# 7780 # (click this combination of keys on the
keyboard in the mobile)
2.- Total Reset or Hard Reset for nokia 6110 Navigator
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
check your phone again it should be fine now
Note i have given the process of soft reset just for reference but a hard reset will do the job for you
Nokia 6110 navigator rear camera not working
I have the same problem and i know what it is. There is a little tiny switch and it turns on Camera when u slide cover down and it is broken. You should take your phone to repair or buy spare part https://www.oemcellphoneparts.com/products/Nokia-6110-LB-Flex-Assembly.html and fix it yourself.
