Just looking for wiring schematic for this motor, as it has many wires. The final arangement will be cc rotation on 120vac.
Wiring diagram will show on label on side of pump.
High voltage and Low voltage.
The rating has to be single-phase and not 3-phase, otherwise motor will not rotate as expected.
Take in-focus photo of label using macro setting on digital camera, and post photo on flickr, and then add a comment with link to that photo.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
The Wiring diagram will show on label on side of pump.
Take
Here is excellent resource for motors:http://www.pool1.com/motor.asp
SOURCE: replacing plug on a 2 speed magnetek 1.5 hp motor
More often than not red is high and black is low. The white is the common and of course green is ground. If High and low are backwards, swap the red and black.
