Should have 10 amp fuse and relay for engine cooling fan and you should have 10 amp ignition fuse and AC RELAY.
If there have some problem on your A/C, may be the Multi-Diag Access J2534 can help you. It has the function for air condition, such as Diagnosis of cooling electronic,
Reading settings cooling circuit,Test servo actuators
http://www.allobd2.com/wholesale/[email protected]
SOURCE: The gauges have stopped working ? Fuse under dash seems to be OK ?
Behind the dash is what they call a constant voltage regulator. It controls the guages. It's small and located behind the dash near speedo.
SOURCE: power window relay or control unit
Control unit (with MANY wires) is inside trunk on right side and there is a fuse box with 3 fuses at the "REAR"...assume trunk again...I have schematic only...remove the Control unit wire connectors and re-insert them to polish the contacts...
SOURCE: rear window defroster, no driver heated seat
check the ground on the passenger side of the rear window under the trim panel. That is what was wrong with mine.
SOURCE: 2001 subaru outback headlight not working
chapmnfarm: your head lights use a "2" fuse system.
one for the left and one for the right.
The fuse box you are looking for is under the hood on the passenger's side. It is a black box roughly 8 inches long and 4-5 inches wide. When you remove the cover, you will see fuses and relays. What you are looking for is the section in the box which has a cluster of 7 fuses. 3 in one row and 4 in the other. On the outer parameter are two relays. The fuses you are interested in are located in the row of 4 fuses, with the two closest to the "L" shaped part of the box. Both of those should be 15 amp fuses.
The fuse below those should be a 20 amp which is the lighting switch and the one below it is a 15 amp which is for the interior lights and the clock.
Check your harness grounds in the engine compartment near the area you have the problem. There are ground wires which come out of the harness on both sides of the core support. The wires are black in color and have "EYES" crimped onto the ends of the wires. Both of them will probably be located about 4-6 inches below the upper tie bar on each side of the radiator. Odds are that the eyes will be large enough to pass a 6mm bolt through.
I hope what I have given you will resolve your problem. Lem me know,,good luck>>>>>>>>>>>>>>>
SOURCE: I NEED A DIAGRAM OF THE FUSEBOX AND RELAY BOXES
On the cover of the fuse box indictes what each fuse/relay controls
