Exercise & Fitness Logo
Cheryl Posted on Oct 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We just bought a use Proform xp 615 trainer. It won't start. When we turn the red button to reset or off it flashes and then goes off. It didn't come with a manuel.
The treadmill will not turn on. It just flashes when we push the red button.
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Oct 01, 2012
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081462
Points
34431
See this video and fix it. God bless you
5 Related Answers
Anonymous
  • Posted on Jan 11, 2009
SOURCE: unfolding the deck on treadmill
From the owners manual:
HOW TO LOWER THE TREADMILL FOR USE
1. Hold the upper end of the treadmill with your right hand.
Pull the latch knob to the left and hold it. It may be necessary
to push the frame forward as you pull the knob to
the left. Pivot the frame downward and release the latch
knob.
2. Hold the metal frame firmly with both hands and lower
it to the floor. CAUTION: Do not grip only the plastic
foot rails or drop the frame to the floor. Bend your legs
and keep your back straight.
Anonymous
  • 294 Answers
  • Posted on Apr 12, 2009
SOURCE: total blackout...neither motor or display
IS THE SAFTY CARD INSTALLED ? MOST TREDMILLS HAVE A SAFTY LOCK OR CARD THAT HAS TO BE IN OR READING FOR THE SYSTEM TO START
Anonymous
  • 16 Answers
  • Posted on Apr 14, 2009
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Anonymous
  • 103 Answers
  • Posted on Dec 16, 2009
SOURCE: how to remove and replace a motor belt on proform
Hello there. To replace the drive belt (motor belt) follow this procedure.
1)Remove power to the machine
2)remove the hood cover (3 screws on the rear of the cover)
3) loosen the adjusting bolts for the walk belt located on the opposite end of the walk belt from the hood assembly. Loosen the adjusting bolts 10 full revolutions. This will loosen the walk belt.
4) You should then walk the drive belt off of the front roller/pulley assembly by pushing the belt to one side while turning the motor. If you are nable to do this you will need to loosen the 2 bolts holding the drive motor in place.
5) After removing the drive belt you can then slide the drive roller to the side out of the frame and it will slide out the other side of the bracket. This will allow the belt to be removed from the front roller and be replaced.
If you had to loosen the bolts holding the motor you will need to retension the drive belt by pulling the drive motor back while tightening the bolts. This will require another person to help tension while you tighten the bolts.
You can then retension the walk belt using the adjusting bolts and retightening them 10 revolutions.
Good Luck Tim
Anonymous
  • 103 Answers
  • Posted on Mar 28, 2010
SOURCE: I have a Proform 350S Cross Trainer Treadmill
http://www.iconservice.com/CustomerService/manuals.do
Input your model number and get a free download.
Good Luck. Tim
I have a proform xp trainer 580 . The display works but the actual walking belt doesnt move.
please see the video and fix it according.God bless youThis happen because the lack of maintenance schedule .
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
1helpful
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Proform 615 xp won't come down from folding it
I am having the exact same problem with my ProForm 615 treadmill. Spent over an hour trying to lower it.
I have a proform xp 580 and my treadmill makes a clicking noise as if it is trying to incline what should i do?
1)Please lube the gear and shaft, very well from elevation motor
2) Test the motor, and replace if necessary.,see for ball bearing and lube
3) Lube the deck belt, and guide for instruction manuals.
4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it.
God bless you
My proform 580 runs for 1/2 second, shuts of, and resets and will repeat this as many times that you push the start button
HI,
Your treadmill have problem with the motor control board. The motor control IGBT is faulty thats why its stars at high speed and shuts off immediately by sensing over current drain. The solution is replacing the motor control board or replacing the IGBT on the motor control board. To replace the IGBT you should have a through knowledge in electronics. If you need any more assistance feel free to contact me through FixYa.
AJIN
My Netgear router has just been replaced by Virgin Media with a DLink 615. The installation disc won't work, so can a connect without it? I'm running on XP and using Firefox as my browser cheers
You will need to reset the router to factory defaults before you can connect to Virgin Moble there should be a reset button on the back of the router press and hold for 30sec. and then reboot it
here is a link to help you setup the router
http://support.dlink.com/emulators/wbr2310/
If you futher assitance lt me know
3helpful
2answers
Treadmill keeps inclining and declining . It won't stop!
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
Does not turn on. When I press the re-set button, it lights up and then goes off again.
Hello. This happened to me when I bought a Pro-form XP 550, and the solution was very simple - There is a magnectic thingy on the front attached by a string to the treadmill. The thingy needs to be stuck to front of the treadmill for it to work. It's some sort of safety device which cuts out the treadmill if you fall off. Is that it? Stephen.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
