This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
SOURCE: Cuisinart Coffe Maker has no power
Talked to Cuisinart tech support today and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults. Worked for me...
SOURCE: One year old coffee maker won't brew
This is my second dcc-2000 with the same problem. I tossed the first one and in less than a year the second one exhibits the same issue. I called the Customer Service (1-800-726-0190). The rep told me to unplug the unit for at least 2 hours adding that this would let the system "reset itself". He then instructed me to run vinegar and water through it to clean the pumping system. I am doubtful about this solution but the rep assured me it would be replaced if I still have problems. It's worth calling CS to get it replaced, however, it seems that this model is flawed by design.
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar
with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of
the unit and in one of the corners you should find a filter stick or
column that is removable. Pull it out and open it up to clean out the
clogged up carbon filter in there. (You can later buy a new filter on
Amazon.) Clean out the debris from the bottom of the cavity. Replace
the stick into the cavity once cleaned. Now it's time to run through a
solution of 2 parts water and 1 part vinegar. Do this once or twice
with fresh solutions, then with a pot of fresh water. When the filter
stick is plugged up the sensor says its time to clean it, but most
people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
SOURCE: The red cleaning light on my cuisinart coffee
Hello sandra_strat,
There are two possible issues, but easy to do. When decalcifying your unit the solution should be 2 parts water and 1 part vinegar. So if you have a 12 cup maker it would be 8 cups water and 4 cups vinegar. Complete the process with a pot or two of fresh water to rinse. Second, there may be a water filter stick that is removable. Open the lid and look for it in one of the corners, pull it out and remove the carbon filter there. (You can get a new on Amazon). Then replace the stick.
I hope this is a help for you. If it is please leave positive feedback for me. Thanks! NormanZ
