Television was working. Had to use the buttons on the television to do any type of adjustments to sound, screen, color, ...etc. During an adjustment period a message appeared in reference to some type of security code procedure and then the television shut off and i have not been able to turn it back on. The standby power button is lit but the television will not work.
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
SOURCE: LG 37LC7D remote doesn't work
I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: cannot adjust the color, brightness, contrast etc, using my olevia remote
how to set TV from High Def to Standard Def TV .. olevia
