My specific model doesn't have a fuse (DMR77LHS). I checked the voltage at the main PBA assy and I'm getting 120v. I followed the instructions in the Service Manual for "Power Relay error" and here are the results. "Check the connections for the Power Relay connector: : Start the cycle by pressing the Power key. Then measure the operating voltage between the black wires of the Heater Relay, and the operating voltage between the yellow and amber wires of the Power Relay. Normal: 120V" - I am getting 110 V "2. Check the door switch. : Check the white wire and the switch connected to the white wire. When the door is open : The Door Switch is OFF. When the door is closed : The Door Switch is ON." - The switch is working just fine "New PBA 3-1.Check the driving signals for the power relay : Measure the voltage between pin 6 (amber) and pin 1 (black) of the CN302 connector on the main PBA. When the door is open or before the cycle starts. Normal: 9.5 to 13 V After the cycle has started by closing the door and pressing the Power key. Normal: 1 V" - I am getting 4.2 v open 0.0 v closed I am not getting any beeps or any indication that there is power to the unit. I tried getting into the service mode "Delay Start + Normal + Power keys at the same time for two seconds", nothing. Can an expert confirm that it's an issue with the PBA board? it's $135 to replace.
SOURCE: convergence service mode
I don't know how to deal with the power settings part but the convergence service mode is "Mute, 1, 8, 3, power".
SOURCE: Door locked open
The 9 was the minutes left in the rinse cycle. I solved the problem noticing that the door fastener had moved slightly to one side and as soon as I straightened it by hand the door closed and I could cancel the cycle. It is working fine now.
SOURCE: Samsung DMR77LHS Dishwasher has power to
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
SOURCE: Samsung ML2571N Fuser Open heat error - Fuser Is Good
Hi Kevin,
The main power supply board in short we call it (SMPS) the error you got is quite common that the main power is not getting in to the transformer in the correct voltage. Normally is to replace the SMPS and the fuser as well.
For more Technical test on the SMPS 1st of all we will test the fuse on the SMPS which is located at the bottom right hand corner. using a multi-tester, 2nd will be the capacitor and 3rd which is the last will be the big and small transformer with power on. note the last test is dangeroures unless you are a electrician experts.
hope this help :)
SamsuTech
SOURCE: No power
The main PSU is part of the control board. You may be lucky to find an aged fuse to replace, but it's more likely a power transistor that's fried.
Unplug and remove the control board to see which bit's toasted. Chances are it's cheaper to replace the control board - but check the probable cause - the motors are not short circuited.
