Onkyo TX-SR705 Receiver Logo
Posted on Dec 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I connect bose 901 speakers to the onkyo tx-sr 706 receiver directly (I do have the equalizer)? if so how should I connect Also I have denon dp-47f turntable, can I connect this to receiver directly?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Nov 30, 2009
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2768080
Points
24828
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on most (all?) AV receivers it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Scott Frye
Level 3:
Genius:
  • Master 1,175 Answers
  • Posted on Jan 19, 2009
Scott Frye
Master
Level 3:
Genius:
Answers
1175
Questions
Helped
503825
Points
2442
Hi...
The Turntable will need a phono pre-amp before you connect to the Onkyo.
Not sure about the 901's
Bose 901 equalizer connect to Lafayette 3500 receiver using bose 901 speakers
The Bose 901 speakers require the use of a specific equalizer that is designed to optimize their performance. If you have a Bose 901 equalizer, you will need to connect it to your Lafayette 3500 receiver in order to properly use the speakers.
Here are the general steps for connecting the Bose 901 equalizer to your Lafayette 3500 receiver:
  1. First, ensure that the power is turned off on both the receiver and the equalizer.
  2. Locate the preamp output jacks on your Lafayette 3500 receiver. These will typically be labeled as "pre out" or "line out".
  3. Connect a pair of RCA cables from the preamp output jacks on your receiver to the input jacks on your Bose 901 equalizer. These jacks are typically labeled as "preamp in" or "line in".
  4. Next, connect another pair of RCA cables from the output jacks on your Bose 901 equalizer to the main amplifier input jacks on your receiver. These jacks are typically labeled as "main in".
  5. Turn on your receiver and equalizer, and ensure that the volume levels are set to a low level before playing any music.
  6. Set the Bose 901 equalizer to the "On" position, and adjust the various equalizer controls to your preferred settings.
  7. Finally, play some music and adjust the volume levels as needed. You should notice a significant improvement in the sound quality of your Bose 901 speakers with the equalizer properly connected.
Note: It's important to use the Bose 901 equalizer specifically designed for the speakers. Using a different equalizer or not using any equalizer at all may result in poor sound quality or damage to the speakers.
1helpful
Help. I purchased a Onkyo Model TX 8555. I then purchase a set of Bose 901 Series V speakers that come with a Bose 901 equalizer. I cannot hook them up. Does anybody know how to do this.
The TX 8555 can drive the speakers directly but if you want to use the equalizer then you need to add an amplifier to the system so that you can feed the pre-amp connections from the TX8555 through the equalizer and then into the amplifier to drive the speakers. This is because the TX 8555 doesn't have a loop back function for monitoring recordings.
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
I just enherited a pair of bose 901 speakers
My suggestion is do not hook the 901's directly to the Onkyo. It is compatable, but they WANT more than what the receiver can give them. I suggest going and getting a dedicated amplifier for them. Trust me, you'll be a lot happier going that route.
2helpful
Proper wiring connection on bose 901 speaker with onkyo tx-sv424 purchase 5 years ago
trying to hook up sereas 2 901 to onkyo sx 424 i have access to carver c 1 if that will help
2answers
Bose 901 iwht tx-sr 706
You will need to connect the speakers to the front channels as you would with any normal set(Speaker + to amp +, speaker - to amp -, etc) then you connect the special Bose equalizer through a tape monitor loop and always have the monitor loop engaged.
2answers
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
2helpful
Bose 901
1-record out from receiver to to equalizer in.
2-equalizer out to tape pb in receiver.
2answers
Onkyo tx sr705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Bose 901 speakers hookup
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
