Duravit 0910100005 Happy D Toilet Cistern  - White Logo
Posted on Dec 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get the top off of my duravit toilet??
I can't see how it comes off.
Stefano Andreani
Level 2:
  • Expert 69 Answers
  • Posted on Jan 05, 2009
Stefano Andreani
Expert
Level 2:
Answers
69
Questions
Helped
23976
Points
104
Try to check if there is any screw on the side of pulling knob...try to pull it and chek around it...good luck!
best rgds Stefano
How do I replace a fill valve in a Duravit Starck toilet?
copy and paste link
https://terrylove.com/forums/index.php?threads/duravit-fill-valve-inlet-valve.83232/
1helpful
How do I replace a toilet seat on duravit happy D toilet
I think our toilet is a Duravit.
Close the seat and the lid then have a look at the back of the hinges. If you can see a small hole in the back of the hinge there will be a grub screw in the hole and you can undo it with an allen key (not sure what size - you'll have to try a couple)
1helpful
The hinges of Duravit toilet cover seat 006331 are broken. Where can I get replacements?
I have not been able to find a "tribeca" on the Duravit website but on the site of one of their parts distributors I found the Duravit Toilet Seat DUR 006331000. Is this your model? Starck 3
On the Duravit website this product looks very similar but not the same number.
I was not able to find replacement hinges for this model sold separately. You might consider using their Find a Retailer feature to find an outlet close to you where you might make inquiries or order hinges and/or a new lid.
1helpful
Does anyone know where to get hold of a manual for installing a toilet from Duravit, please? Specifically it is the Duraplus 022901. With many thanks, Fran.
Information on your product can be found here along with measurements for installation. However there does not seem to be detailed installation instructions.
http://www.duravit.com/products/series/duraplus/toilets/toilet-close-coupled--022901_toilets_91994_useo6q3rng.html#
Suggest you review the following series of videos which provides detailed instructions on toilet removal and replacement.
Trust this is helpful.
2helpful
How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
13helpful
3answers
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
1helpful
2answers
My duravit toilet keeps running
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
17helpful
4answers
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Top Duravit Home Experts
Mike Cairns
Mike Cairns
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Duravit Home Expert? Answer questions, earn points and help others
