20 Most Recent
Duravit Duraplus, Two-Piece Toilet - D13018 Questions & Answers
Water source to tank will
Hi carolekendal...
You have a blockage in the fill unit of the toilet...
You will need to replace the internal "ballcock" and I would also replace the "flapper valve", you can get all the parts and the info on how to replace it from some most of the warehouse stores such as Lowes,Home Depot, Ace Hardware,etc..
It is not a very compllicate job.
Free Answer...Please rate me
4/22/2011 1:15:06 AM •
Duravit...
Answered
on Apr 22, 2011
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
10/5/2017 4:34:53 AM •
Duravit Home
Answered
on Oct 05, 2017
