Color separation from center to right edge. Vertical blue band runs from center to within 3" of right edge, then vertical red band to edge of screen. Picture remains visible behind color bands.
1. Unplug unit from wall for 3 minutes;
2. Press & hold Power button for 1 minute;
3. Plug in unit.
OR:
1. Unplug for 3 minutes.
2. Plug in unit.
3. HOLD Power Button as unit starts ... hold until the unit flickers on then off twice.
This effectively returns the components to factory specs, much like resetting a computer. It offers a *temporary* fix, lasting 45 minutes to hours. All depends on the unit.
Mom has an Insignia 32" with the same color separation problem, which worsens as the day progresses. Best results achieved while television is cold.
Dust in the unit could contribute to the problem ... try to keep the unit dust free as possible.
SOURCE: insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
SOURCE: Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
