I took the bobbin case out so that I could clean out the dust and now it won't slide back in.
Here's a link for inserting a bobbin into a machine
http://www.youtube.com/watch?v=ZX3LjiYOLsg
here's some links for a manual for the machine
http://www.sewingpartsonline.com/instruction-manual-necchi-4575.aspx
http://www.sewingpartsonline.com/instruction-manual-necchi-4575-download.aspx
SOURCE: Necchi 4575
I've found that my machine doesn't like Coats & Clark thread; I have to feed it Guterman
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
SOURCE: top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
SOURCE: bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
I know how to put the bobbin in but I can't do that if the whole case is taken out. I'm having trouble getting it to go back in so that I can put the bobbin in and sew once again.
