The fan had greasy dust all caked on, I strayed it with fantastick and whiipped off the dust. After it go wet. It refused to work. Will it dry out and work? Is it a fuse.
Wow... you must have got it really wet ! but if that is why it is not working now, then set it out in the sun for a few hours, or put it in front of another fan. hope this helps. post if it does. There are other problems it could be and I may be able to help with that as well. first things first. good luck. Tim
Testimonial: "I did dry it out but the fuse brought the pwr back."
Yes, The Fan was very black dirty. I noticed it had a fuse and it came with an extraa
The electrical plug fuse(5a125v) was changed and the power was back. T
Thanks for your input.Bionaire was going to replace it.Now will buy another
Maybe,I will remove the fuse when I clean it.
5yr warranty, Love this Fan.
I am really happy for you, & thanx for responding to my Ideas that could help you. Most people don't say anything, much less thank's. Hope you enjoy your fan for years to come... have a great evening... ;O) Tim
Today the fan blew again. The temp w/on/off and died. I got to call it in again
Sorry for the bad news but I will try another fuse when I get it.
Here is the basic idea on how to keep the
refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved
by an electric fan or blower in order for that product to work properly. If air
movement is blocked the fridge won't get cold, the central air conditioner
won't cool enough, the vacume cleaner won't clean as well. Check on your
fridge's air movement by inspecting the bottom of the fridge for dust and cob
webs. Remove the front bottom clip-on plastic grill. Or also even access the
lower back of the fridge by removeing
the screws holding up the heavy cardboard cover to see inside. Blockage
of air flow will prevent a fridge from getting cold. Just like a vacume
cleaner stops working when the bag is filled with dust and fibers.
The air could be blocked by the accumulation of dust and
fibers. Look under your fridge if it is
cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air
movement from back to front (or visa-versa) of your fridge will slowly (years)
prevent how good it cools. The build-up of dust and cobwebs prevents your
fridge from cooling (more specifically prevents the heat to disapate
from the metal heat disipating fins
attached to the metal tubes to be blown off by the fans air). OK! Remedy
for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE
CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge
manufacturers do not provide a dust filter like the vacume cleaner and central
air systems manufacturers do. You have to figger out
the best way you can clean it. Possibly vacuum with a crevice tool, or use
a small brush than vacuum. The extreme would be unplug
the fridge ( so you won't get electrocuted) bring
a water hose into the kitchen and spray water at cobweb buildup at the bottom
fridge, than wet vac the floor then wait
20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front
of your fridge and you hear the fridge electric motor turn on, the fan will
blow air.The fridge
of air flow will prevent a fridge from getting cold. Just like a vacuum
cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and
blow air out the bottom.The fridge
blow air.The fridge
