Posted on Dec 25, 2008
Hourglass is flashing on and off the whole time - mp4 player does
Mp4 player does not turn on, hourglass flashes on and off,nothing else
  • 1 more comment
  • ilammar66 Dec 26, 2008
    I HAVE THE SAME PROBLEM WITH MY MP4..BRAND NAME CYBERTEC MADE IN CHINA...
  • Eltaro Dec 30, 2008
    Same here, this is bull XD please someone help
  • Anonymous Mar 20, 2009
    I have the same problem and the machine doesn't seem to want to charge.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
479
Points
Wilson sony s1 mp3 player is on but not recognize
1helpful
I have a Craig CMP616F MP4 player. It just flashes an hourglass. No menu. No nothing. Just bought it.
I had the same problem with mine several times. One time, I was able to turn it off and the hourglass went away and it started working better Usually when that happens it means the files on the player have been corupt; therefore, you have to hook it to your computer and delete all of the files off of the player. I even had to format the player's drive once after I deleted the files (since I did that I haven't had any other problems with it freezing with the hourglass on the screen)
Mp4 player wont register as a device on my PC
Just follow these steps below:
To check if is really connected to your pc.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
You can try to format it with fat files system or the file system you are accustomed with if there is nothing important on it.
hope this help you
Regards
uttam
2helpful
Flashes on ad off with hourglass symbol how can i fix or reboot. Its an Craig mps player
I've had this problem a few times with my craig mp3/mp4 player, and I found if you let the battery run all the way thru, then turn it off, plug it back into your computer, and turn it back on.....it will load to the "connect" screen.
Mp4 locked displaying hourglass
nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnothinh helps uu man
3answers
Cheap mp4 player (annoying)
i have a delstar mp4 player and when ever i trun it on a hourglass comes on so how do a get it to work?????
5helpful
4answers
Craig Mp4 player problems
keep it on for a few days intil it turns off then plug it hold play button then press menu then it should work
2answers
click and the middle button until hour class goes away..may take a minute or two
5helpful
6answers
Delstar Mp4 player
I HAVE 3 delstar mp4 player and it worked fine for a few months. I plugged it in to charge, took it off the charger and now it is frozen on a blue screen with an hourglass design. What's wrong and how can it be fixed? Help please ALSO I FORGOT TO MENTION THAT NONE OF THE 3 MP3/MP4 TURNS ON AT ALL. PLEASE HELP....
1helpful
3answers
AdfuUd.sys file missing
My mp3/4 digital player cannot start, when I turn it on its screen shows an hourglass and stops by there, it cant go . when I insert the driver CD I got with it for installation it stops along the way asking for a missing file called "AdfuUd.sys ".Besides, it has no manufacturer...
Top JNC Computers Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a JNC Computers Audio Player and Recorder Expert? Answer questions, earn points and help others
