20 Most Recent Philips SA3125\02 MP3 Player Questions & Answers
5answers
I have a problem converting certain videos to
only wav videos can be converted
7/8/2021 3:20:34 AM • Philips... • Answered on Jul 08, 2021
2answers
Nao quer ligar
como fazer para ativar o gestor de dispositivo para repara?
12/17/2013 10:15:50 PM • Philips... • Answered on Dec 17, 2013
2answers
What should be done to convert youtube videos to
Use a format converter to change the formats of your you tube videos to the format you need. I hope this helped, Please rate me, Thanks
You can download a free format convert at the following website: http://www.formatoz.com/
12/17/2013 5:52:23 AM • Philips... • Answered on Dec 17, 2013
I have an 02 buick p.a. battery, relays fuses have all been checked and r good when I turn the key the dash lights up but when I turn the key all the way it doesn't make a sound
Remove battery terminals and clean both posts and terminalswith sandpaper until you see shiny metal. The black coating is lead sulphate which has a high resistance to current flow both into and out of the battery. Have a load test done on the battery for a failing cell
6/4/2013 7:53:55 AM • Philips... • Answered on Jun 04, 2013
My GoGear Aria 8GB won't turn on! I've tried the
this also happens to me a while a go ., just charge your go gear ariaz 8gb on a direct electrity plug in your usb charger maybe it was too drain
2/15/2013 5:37:36 AM • Philips... • Answered on Feb 15, 2013
2answers
My Philips SA52xx GoGear MP4 Player won't start up.
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
1/14/2013 3:34:07 PM • Philips... • Answered on Jan 14, 2013
4answers
Philips GoGear SA3125 MP3 Player - won't turn on
I have the same problem right from day dot.... have found that using a pin on the reset button gets it back on every time! But the problem keeps coming back. I believe its a software bug on these units. Dont try and fix it... take it back and get something else!
11/26/2011 2:41:25 AM • Philips... • Answered on Nov 26, 2011
2answers
How can I convert a i3e file?
Go to this website and download the free file converter.
Good luck,
I hope this helps
11/9/2011 4:17:16 PM • Philips... • Answered on Nov 09, 2011
My Philips GoGear Aria (8GB)
Hi poseidonisco,
I would attempt a Repair/Recovery, which will restore your device to factory settings as well as update the firmware and improve functionality of your player.
You can find a lot of valuable information on the Philips Support Site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3125/37&slg=en&scy=US
After performing the Repair, allow your player to charge for several hours and be sure to practice a regular charging routine. If you have any additional questions, you can chat at the above link or you can reach Consumer Care at 1-888-744-5477.
Hope this helps! If so, let me know by rating this solution. Thanks!
REPAIR INSTRUCTIONS:
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
8/8/2011 5:12:51 PM • Philips... • Answered on Aug 08, 2011
It was running and then
You should try to repair the player using Philips Device Manager. The procedure that you should do is described detailed step by step at the manufacturer's web site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=BE&slg=ENG&sct=PORTABLE_VIDEO_PLAYERS_SU&cat=MP3_AND_MEDIA_PLAYERS_CA&grp=SOUND_AND_VISION_GR&session=20100703194931_66.249.65.15&ctn=SA3125/02&list=aa12_list_partial.html&mid=Link_DiagnosticInformationTool&hlt=Link_DiagnosticInformationTool
At first select the category "communication with the PC" and follow the instructions you get there.
Finally you will get to the state "repair function" and you will be able to hope successful action.
gylacz
7/20/2011 1:44:32 PM • Philips... • Answered on Jul 20, 2011
My mp3 player just blinks
Make sure you are using the correct power cable. If you are charging from USB and it still blinks, you may need to contact Philips for service. If you are charging from a wall outlet, try using the USB cable instead to eliminate the possibility of a wrong cord.
4/17/2011 8:00:49 PM • Philips... • Answered on Apr 17, 2011
Memory full
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
4/7/2011 1:14:00 AM • Philips... • Answered on Apr 07, 2011
Problem with the Philips SA3525\97
Via this link you can download the device manager:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3125/97&scy=hu&slg=hu&mid=Link_Software
Install the software on to your PC and try to connect the device to the usb port. If the PC doesn't see the device you should download the firmware upgrade software from this link also.
With this you can repair your player.
I hope I could help you,
Thanks
gylacz
4/5/2011 11:07:34 AM • Philips... • Answered on Apr 05, 2011
2answers
How to put videos into my philips go gear aria?
just add your video into video converter, and choose output format, then click convert, it will be changed into mp4 files, so you can import it to your philips, http://www.leawo.com/video-converter/free-mp4converter.html
2/22/2011 9:58:08 AM • Philips... • Answered on Feb 22, 2011
Every time I turn the
via this link you can download the device manager:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=ua&mid=Link_Software&ctn=SA3125/02
bye, gylacz
2/7/2011 9:31:42 AM • Philips... • Answered on Feb 07, 2011
14answers
Converting file to video format ( i.e. SMV format)
Get another video converter and convert it to Windows Media Video (WMV) then convert it to SMV videos from there. IT works 100% Guaranteed.
1/17/2011 2:16:35 PM • Philips... • Answered on Jan 17, 2011
Hey, my mp4 philips go gear
get a pin or a tack and hit the smale pin siz hol on the botom or top
1/6/2011 10:15:33 PM • Philips... • Answered on Jan 06, 2011
I already converted videos to .wmv format but
I think I can recommend an excellent video convert tool to you, for which is Video Download Studio.
Except for convert, it can also help you with video download,trim,crop function.
Get a free trial from http://www.downloadvideos-convert.com/download-videos-music
Hope it can help you more or less!
10/23/2010 2:46:23 AM • Philips... • Answered on Oct 23, 2010
When i turn on my
your player should have came with a disc that you can put in your computers cd or dvd drive. install the device manager and from there you can do updates and repairs.
10/19/2010 10:50:01 PM • Philips... • Answered on Oct 19, 2010
Philips SA3125\02 MP3 Player Logo
113 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
philips sa52xx gogear mp4 player start
  • Audio Players & Recorders
